Question Carbide spec - 02 replacement case
Jul 14, 2019
18
4
25
Was planning on purchasing a carbide spec - 02 (with the red lighting) for my new build, but it seems to be out of stock everywhere I look. And it isn't even showing up on corsair's website.
Any suggestions on a replacement case of similar size and quality for the same price? Going to be putting a B450 tomahawk in it if that makes a difference.
Thanks in advance.
Not surprising, its an older case, I have the exact one in my old build. Where are you buying from? and whats your budget?
Was going to purchase it from Amazon for sake of convenience, but any reputable online dealer is fine honestly. I think the case +an extra fan, which was the deal Amazon had for it was around $90. So that is around what I am looking to spend.
