Hello everyone. Long story short, i cascaded my ISP provided modem( ZTE ZXHN H298A) with TP-LINK Archer vr300(this will be second modem) via lan to lan connection in order to extend my wifi range. I turned off the DHCP server on the tplink and turn off all the firewalls on both modems and unpnp and nat. I choose different channels and same SSID, same passwords. So instead of simultanious switch between first and second router depending on the signal strength, when my devices tries to switch from 1st to 2nd modem, it fails and no internet connection. It looks like it is connected but no internet access. From 2nd modem to 1st modem is just fine, no problem. So then i thought that i can change the SSID and make them seperate and switch back and forth manually, so i did that. Now, if i disconnect from 2nd router and connect to the 1st, it is ok, but if i try to disconnect from 1st and join the 2nd, it fails. I have to try for like 10 minutes and then it connects. So my real problem is that i have experiencing a connection issues to my 2nd modem and i dont know why, i factory resset it like a dozen of times. Also in the interface of the second modem it shows that no internet connection but in fact there is internet connection and i can use it fine if i can connect.
Side note: I was using this TPLINK modem as my primary and there was no issues at all. So it is not a hardware related problem. But now, i have to use the ISP provided modem for my internet access.
