Hello everyone.
TL;DR : My PC’s fans are driving me crazy. Because High temperatures. Because IAO dead. I need a new case and cooling system to improve the noise.
My fan goes crazy because the temperature is sky high (100°C) quite often. From the replies I got from another support, it seems my AIO is dead / dying and I'm recommended to switch it with a fan system, such as the Thermalright Peerless Assassin for the LGA 1151 socket.
In addition to the replacement of a faulty/old component, I want to prepare the upgrade of my 6+ year old pc.
I humbly ask you to help me find a case (and cooling and all other necessary components) to improve the noise attenuation and handle future upgrades. If possible, I'd like to evolve things over time, rather than replace everything at once. So budget is not a major constraint.
Although I use my PC every day for work and leisure, I'm not a technician or hardware connoisseur. I'm f*cking lost between the compatibility of :
My current use: office, “light” games, a little streaming
Future use: office + AAA games + video design + VR on PC + stream (so, in the future, i will go for heavy GPU and CPU)
Case specs:
https://pcpartpicker.com/list/T4B8gB
Case: Aerocool P7-C1 Glass Edition
Motherboard: Asus TUF Z370-Plus Gaming
Processor: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
CPU fans: Cooler Master Seidon 120V
Graphic card:
PSU: be quiet! Pure power 10 L10-cm-700w
Hard Disk: 3000Gb TOSHIBA DT01ACA300
SSD Disk: 500Gb Samsung SSD 850 EVO
Wifi & BT: Wifi 867Mbps + Bluetooth 4.0
OS: Windows 10 Pro 64x
Screens:
Thank you everyone, for your time and advises.
May the FPS be with you.
- Which case would you recommend? (my case specification are below)
- What components of my current system should I remove and replace (e.g. faulty cooling system...)? (my PC parts are below)
- What other components should I add directly to this case?
- Any other recommendations?
- the current components
- the current components with the first "wave" of upgrades (such as a new cooling system)
- the old components and first wave with the new case
- the first wave with those from a second wave of upgrades (new CPU, GPU, etc.)
Case specs:
- Super-Tower or Big/Full tower case for future upgrades (since i will have to change hardware regularly from now on)
- Extra silent
- Sound isolation
- E-ATX format (for space hungry upgrades)
- Total blackout. No rgb bullsh*t. I want it to be as dark as my humor or my coffee. If i could paint it with Vantablack, I would 😀
- I don't care to see what's inside the computer
- Filters / easy cleaning
- Low temperature --> great airflow? Fans for push/pull or push/push, maybe? Bonus point for prebuilt because i’m newbie. Or at least, a good instruction video.
- Ability to add extra drive in the future
- Room space isn't a big problem
- Corsair Obsidian 1000D (costly but could follow me for a long time)
- Fractal Design Meshify 2 XL
- be quiet! Dark Base Pro 901 ATX Full Tower Case
Graphic card:
- Geforce GTX 1080Ti 11Gb
- Intel UHD Graphics 630
Screens:
- iiyama PLE2483H on the Intel UHD Graphics 630
- LG Ultragear on the Geforce
- Philips FTV on the Geforce
