I have the case which can be seen on the following images:
It's a very cheap case... It has a top-mounted PSU, which I plan to replace with (already have it, did not install it yet):
XFX TS Series P1550SXXB9 550W ATX12V 2.2 & ESP12V 2.91 SLI Ready CrossFire Ready 80 PLUS Bronze Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
As you can see... The PSU fan is on the bottom.
Being that the case is made for a top-mounted PSU, I don't if it's right to place it there with just the fan pointing down.
Also... I will be installing a new GPU also (to run with the aforementioned PSU):
SAPPHIRE DUAL-X 100370L Radeon R7 265 2GB 256-Bit GDDR5 PCI Express 3.0 CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202096
The only fan on the case is the one which can be seen on the side... I have the rear and the 2 bottom fan slots free. This case has NO front fan...
Please advice me on the best way to set up the case... I have some tools to make some modifications if they are worth it... My friends insist I buy a new case... But I already spent quite some money on the PSU and the GPU.
Thanks in advance
Thanks in advance
