I have a Cooler Master H500 enclosure. I use the default mesh front, not the available acrylic panel.
For cooling, I have:
2 x 200mm (came with case) doing intake at the front
1 x 120mm (replaced the included fan with an RGB) doing exhaust at the back
I also have a DeepCool GammaxGT CPU cooler with a 120mm fan blowing into the heat-sink towards the exhaust.
All pretty standard.
I now have another 2x120mm fans available to me. I was thinking about putting them in the top of the H500 where there is room for 2x120 or 2x140 or 1x200mm.
The main question I have is should these be:
I was leaning towards 2x intake to create a positive pressure but is it too much intake with only a single exhaust?
Any advice would be appreciated!
Cheers
- 2x120mm intake (so intake above the CPU cooler)
- 2x120mm exhaust (to take air away from the case above the CPU cooler)
- 1x120mm intake (front or back?) and 1x120mm exhaust (front or back?)
Cheers
