[SOLVED] Case fan auto pwm or voltage?
Leave it on auto. The motherboard should be able to figure it out.
Otherwise if you want to set it manually to be certain:
  • 4-pin fan = PWM
  • 3-pin fan = Voltage
choose pwm.It will help reduce the noise. but many gigabyte boards are faulty, if you choose voltage it will be pwm mode, and pwm will be voltage mode and will always spin at full speed
