case fan connector enquiry
Derick0
Commendable
Mar 25, 2017
18
im gonna have 3 fans in my build but my motherboard (Asus H110M-K Intel H110 ) which i think has only 1 x CPU Fan connector (1 x 4 -pin) and 1 x Chassis Fan connector(s) (1 x 4 -pin)
from what i understand the chasis connector is just for connecting fans to psu?
Does that mean i will only be able to connect my fans to the psu? as well as meaning i wont be able to adjust fan speed?
and how can i connect all 3 fans to the one connector?
No. The chassis fan connector is to allow you to power and control a case fan from the motherboard.
General rule is that you should not exceed 1 amp draw on the fan headers.
If you connect your fans to the psu, it will run at a static speed. You can buy adapters which makes the fans run at 12V, 7V or 5V or get a fan controller.
