Hi,
Im building my pc, and I have the Fractal design define S2 case, and it has preinstalled 2x 140mm front and 1x140mm back. I plan to use my Noctua NH-D15s the fan in the same direction as the front and rear fans so it blows in the same direction.
My question is that I have 3 extra 140mm fans that I could install. How should I install the extra fans, i've read that its not a good idea to put the top fans on top of the cpu cooler for exhaust air outake, because it could blow air from the GPU more into the CPU.
So should I just install 1 more front fan and maybe 2 bottom intake fans ? Or just the 1 front 1 bottom and 1 top exhaust ?
Also do you think this case is enough for a standard gaming case, I've read that its not so much hotter than the Fractal meshify, I don't plan to overclock or anything like that. Also would a full E-ATX tower be more cooler and future proofed ?
