I just bought a case fan to install on the back grating of my Dell XPS 420 to increase airflow since I am planning on upgrading more components. It has a male and a female 4 pin Molex connector, which I guess is for daisy-chaining.
I attached an open 4 pin connector from my PSU to the connector on the fan.When I booted up, I noticed the fan never turned on. I checked my connection to make sure it wasn't loose, but everything was fine.
I just need to get more exhaust out of the back of my case. I think the included back fan is located in a small space above my PSU to cool it.
I have no idea what to try at this point
... I couldn't find any open 3/4 pin motherboard connections either. Maybe I can get a Molex adaptor to plug into an open SATA port or PCI slot?
