Case fan plug in
If you've already plugged in the smaller connection, you don't need to connect the larger Molex one.. it is an alternative power connection if you don't have any small fan headers left available on the motherboard. Also note that the Molex connection is strictly power and the fan will run at full speed always, whereas the smaller connection has an RPM sensor wire that could allow you to control fan speed thru BIOS or software.
