I am building inside a phenom m mATX case. Currently I am using:
2x gentle typhoons 120mm 1450rpm in the top pulling in. (This is how the phenom is meant to draw air so don't tell me to make them exhaust please)
1x h60 with standard 120mm pulling cooler air in from outside.
1x 200mm bitfenix rated for around 150cfm exhausting.
I plan to put filters on the intakes. Which I know will cut down on their cfm for intake.
I'm worried about creating negative or neutral presure in the case.
Can some one lend some insight?
