[SOLVED] Case fan rpm
Nov 17, 2018
9
I got 2 fan on the front to suck air in, 1 on the back and one on top to blow air out. What is the rpm setting for case fan. I don't mind noises. Please help me out
Well Ive set mine to the lowest since they have good cfm (from antec h20 aio stolen).
Put your hand and ramp up fans, with speedfan you can do that in real time.
Are you ocing? High temps?
System specs?
And to add mostly under 50-70*C is safe. Except for hdd which has to be under 50*C
