My case has two stock 120mm fans included (front and back). What I want to do is remove the front fan and replace it with the type of fan setup you'd get from the radiator for a liquid cooling system, but use that as an intake instead. Are there any fans out there that would meet this goal (two 120s hooked up to one header)?
Edit: Case is a Fractal Designs Define Mini C, and I have an MSI H110M motherboard, if that info is needed.
