I recently built my first pc and everything works fine except for the fans that came with my case, as well as the case itself in regards to the LED's on them. The fans run fine and the case ports and buttons work but the LED's won't light up. I've checked multiple times to make sure that my motherboard ports are in the correct spot as well. The reason I'm stuck is because my case came with a little plug in motherboard type of thing which the case fans connect to and is powered through my PSU. So when I go into the bios it technically doesn't recognize my fans because they aren't directly ported into my motherboard even though the LED, reset, power switch run through this case board. My RGB Ram and motherboard do work however and show up in the bios. I have a B450 MSI Tomahawk and my case is the Rainbow V2 and any help would be appreciated. Thanks in advance.
