I recently have been having a problem with my computer crashing out intermittently. I've checked temperatures with Core Temp and haven't seen anything unusual there, and I haven't been able to identify anything specific happening before the crashes. Of course, it's possible that there could be a temperature problem at the exact times of the crashes, and I'm just seeing normal temps when I look at the app in between.
Every time, the case fans spin up to a high speed and become very loud, and the screen goes black. The power light on the case stays turned on, but I can't recover without resetting the system. If I hit the reset button on the case, the computer will restart like usual and boot up into Windows 10 without any trouble. I also can power it down and do a cold boot with no issues. I've had no other problems with the system, aside from this new loud fan/crashing issue.
I'm not positive, but I think this started happening after a recent Windows 10 update that I ran about a week or so ago. That could be coincidental, but I'm wondering if that update could have messed something up. I don't know how to check that out, though.
Could someone help me identify what's causing this and how to fix it? Here are my current specs:
OS: Windows 10 Version 10.0.18362 Build 18362
CPU: Intel Core i5-3570K CPU @ 3.40 GHz, 3401 Mhz, 4 Cores, 4 Logical Processors
Motherboard: ASRock Z77 Extreme4
Installed RAM: 16GB
Video: NVIDIA GeForce GTX 1070
I'm not sure what other info you might need, but I'll be happy to supply any additional details.
Thanks!
Installed RAM: 16GB
Thanks!
