Hello good people. I am starting my first PC build, and I've found many answers here about how to build it right (preparation is important, right?) But there are few questions I couldn't found an answer to.
First, question is about case fan control. My motherboard (Gigabyte GA-A320M-S2H V2) has only 2 Fan plugs (one for CPU, one System fan), so I decided to buy myself a hub of this kind
https://www.amazon.de/gp/product/B07D7RQTQX/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I've got 3 Arctic F12 PWM Coolers from my friend, so I want to plug them in. I suppose the fan control will work fine with the hub, according what I found here. But my case (Cooler Master E500L) has one pre-built fan, which is a 3pin fan (Cooler Master Silent Fan 120). Do anyone know if I plug a 3pin fan to that hub, will it run with full speed or it'll run with the same RPM as the 4pin ones?
Second question is fan placement. I want to put 2 front intake, one back and one top exhaust. Since the Arctic has higher CFM (53 vs 44), I'll use them as intake fans. But for exhaust, which one should I put as top and which as back exhaust?
Thank you for your answers
Btw, my setup
CPU: AMD Ryzen 5 2600
CPU Cooler: AMD Wraith Spire
MoBo: Gigabyte GA-A320M-S2H V2
GPU: Gigabyte Radeon RX580 Gaming 8G
RAM: Corsair Vengeance LPX 1x8GB 2400
Storage: 240GB Kingston A400 SSD + 700GB Toshiba 2.5' 7200rpm HDD (from my old laptop)
PSU: Corsair CX550M
Case: Cooler Master E500L
Case Fans: 3x Arctic F12 PWM + 1x Cooler Master Silent Fan 120
Btw, my setup
PSU: Corsair CX550M
