Question Case Fans not spinning.
Mar 27, 2020
After installing a new Gigabyte X570 UD Motherboard my Case Fans that were previously working no longer work. The fans all connect to cables that go up into the top of my case and into a console that controls Case Fan speed and Lights. I have a Red SATA cable that comes from there and I have it plugged in, but it appears to do nothing. I also have a 4-pin Molex cable that I have plugged directly into a power cable connected to the Power Supply, which also does nothing. The case is (I believe) https://www.newegg.com/p/N82E16811103033 . It's been a long time since I bought it. Also worth noting is I installed a Ryzen 5 3600X CPU into the motherboard as well. Please help. 🤞
