Case for B450 tomahawk
nozzy7
242
So I got a B450 tomahawk. And I wasn't paying attention when I bought a case and got a micro atx case. Any way I realized the tomahawk is a very large motherboard. My question is would the tomahawk fit in a mid tower? I am having trouble finding a spec page with the tomahawks size listed. Do I need a full tower or can I use a mid tower? Does the tomahawk fall under EATX or standard ATX?
Any help would be great!
Thanks
This graphic will help you -
There is no spec standardized specs for mid-tower and full tower cases. Many times a mid-tower case can support an ATX mobo, which the Tomahawk is. Can you provide the model of the case and we can tell you if the Tomahawk can fit. You are looking for a case that supports and ATX motherboard.
Thank you for the link. I couldn't find a detailed size for the life of me.
