The LEDs on my case are not working. There is a button to switch between the case controlling the LEDs, or the motherboard controlling the LEDs. There are two blue LEDs near the the button, and they are both lit up, and pressing the button does not change anything.
Here are all of my specs:
i7-8700K
GTX 1070 Ti * 2
8 GB RAM * 4
Asus Prime Z370 A
Corsair RM1000i
Enermax Saberay RGB case
I also have an Asus LED SLI bridge, that plugs in with a cable. So the LEd cable for the case plugs into the SLI cable which plugs into the motherboard. I took it apart to check the cable connection here and everything was fine.
Here are some pictures:
Any ideas?
i7-8700K
GTX 1070 Ti * 2
8 GB RAM * 4
Asus Prime Z370 A
Corsair RM1000i
Any ideas?
