I was messing with my case tonight (coolermaster masterbox) to see if I had loose wires/ cpu cooler coming loose just examining while I cleaned it out and decided to retighten my gpu screws that hold the gpu in and stripped the case outpaet out so I don't have screws holding it in , I then noticed this case wasn't new when I bought this pc as the lower screws have been used and it wasn't by me so it was most likely stripped already, I have been doing things with this pc for a few days now to try to fix the issues I have had just to have this happen 😢, I'm fed up and tired of sinking money into this thing when I could of already built a pc with a better mobo/processor as much as I've spent upgrading things in this I didn't know needed upgraded when I bought it!
Anyways I'm looking for a case recommendation something not cheap made and easy to build in so when I do upgrade it will be here
I have a msi b550m pro vdh wifi motherboard.
Ryzen 5 3600 cpu stock cooler (might as we upgrade that while I'm at it)
Asus ko 3060ti 8 gb gpu
Seasonic gold focus 850 watt psu
I have 5 case fans in this (just ordered all the cables to hook them up finally)
1 m.2
1 ssd
I don't know what else you all need to know I'm Just super bummed out and want to get this headache over with, my next upgrade is a X570 with a 5900x
1 m.2
1 ssd
