Question Case recommendation
kisserik93
47
Hello!
A few weeks ago I decided to replace my current computer.
This is the specification of the new machine:
Processor: AMD 7800x3d
Motherboard: ATX size
VGA: Asus TUF 7900 XTX OC
Processor cooling: Artic Liquid Freezer II 360
I would like to ask for your help in which of the listed houses is the most ideal:
1. NZXT H9 flow
2. O11 Dynamic EVO XL
3. Be!quiet SILENT BASE 802
4. Fractal Design Meshify 2 xl
What is important to me is that the machine is as quiet as possible, but can also provide excellent temperatures.
I like the H9 Flow the best, but I saw in the videos that when the video card is used horizontally, the video card power cable is very close to the glass. This worries me a bit.
Basically, I would be interested in which case has the quietest, most ideal, best temperatures.
If you recommend a completely different case, I'd be happy to see it too.
Hi!
That depends on multiple combinations that, a solid response can't be provided:
-the case design.
-the case fans you will use, placement/orientation, and personal fan curves.
-room ambient.
-case ambient.
-AIO placement is a catch 22 in regards to airflow and temperatures, and there's also your personal fan curve for those fans.
-vertical/horizontal gpu cooler and personal fan curve.
You are the one who ultimately determines that goal, not the choice of case - except for obviously poor ones, and that's none of these.
It is entirely possible to pick any one of those 4 cases, then make decisions that work with your hardware selection, or hinder it in some manner.
If the H9 Flow is your favorite pick, then work/roll with it. If power cables are a concern, then look into custom cables/adapters that are compatible with your power supply. Corsair and Cablemod are 2 companies that offer them.
