Hello all!
I'm preparing for a new build. I haven't yet decided if I'll go i9-13900K or Ryzen 7950 with the CPU.
But the GPU will most likely be a 7900xtx. I have my eyes on a ASRock RX 7900 XTX AQUA if I can find a palce that will sell them. Or maybe i can settle for a 6900xt if theres a good sale for a one with a factory installed waterblock.
Now to the point. I will repurpose a MO-RA3 360 core from my current pc. My plan is to build an external watercooling in a plywood box containing the rad, fans, pump and res. I don't think I will overclock, but it is an option I like to keep open. My point of watercooling is mostly silence. As it has been for the past 8 years. But I was never fully satisfied with my current pc's noise level.
I just orderer a Be quiet pure base 600 case.
Now I'm thinking about the heat build-up inside the case with this configuration. Should I be worried about cooling the mobo, NVMEs or rams? The case comes with one 120mm exhaust fan and one 140mm inlet. Should I consider a mobo waterblock?
Thanks!
Thanks!
