Case that's less than 400mm long
andypearce
162
Hi Guys,
Very quick question for you all. I'm building a PC for a friend, however due to a shortage of space where he's going to be putting the PC we ideally need a case that's 400mm or less in terms of length. This case needs to be able to support a full ATX motherboard.
I've had a good look around and can't really find anything suitable. Have you guys come across anything that you might be able to point me in the direction of? I'd really appreciate it!
Thanks.
Andy
I had the same issue of limited depth.
Because I could use a M-ATX motherboard, I was able to use a Silverstone TJ-08E which is only 380mm deep.
I highly recommend it because of excellent cooling and can handle full size components.
The PS-07 is similar in size.
Question??? does your friend really need 7 expansion slots vs. the 4 on a M-ATX format.
To answer your question, I have done some research on full size ATX motherboards, and I think the Anidees A17 would fit your needs at 380mm deep
http://www.anidees.com/ai7/ai7black
