Question Case with 240mm top radiator! Need help!
biL4
19
Well here we go again. Got some parts that are listed below and reached the case selection moment.
I5 9600k
Gigabyte Aorus Z390 Ultra
Corsair H100i RGB Platinum 240mm
16gb dual channel Trident Z 3000mhz
Seasonic 620w
Sapphire RX 590 Special Edition
500gb M2 Samsung Evo Plus SSD
Got stuck at case selection. I want a case that will support the 240mm radiator at the top, as exhaust. I know that opinions are shared between front and top radiator but considering that the cooler is kind of overkill for this CPU and I don't want to throw an extra buck on exhaust fans I will go with top radiator. Budget 100 $€
Also it should have a side glass panel.
So all suggestions are appreciated! Thnx!
