I've decided to get Cooler Master MasterBox Pro 5 RGB but it says that the motherboard needs to be compatible in order to have the RGB effect. Is Gigabyte B360m Auros 3 compatible with it?
Is it a good case? I'm on a tight budget so I want to buy something really good in this budget. Can go lower than this but not higher than this.
I'm getting a Corsair Carbide Spec 04 really cheap from my cousin but I thought I should some beast once and for all. Please recommend.
