Cassette to MP3 without using Computer
johnrenosh
I have almost 100+ cassettes which I need to digitize. I am looking for a device that will play and convert it to digital format(mp3) without having it to connect to PC/laptop. I could find some chinese products that does this functionality. I am looking for a reliable product that can help me do this...
There are devices that will do this, but ask yourself this:
1. do you want to be able to edit the cassettes and sort the files into 'tracks'
2. do you want to be able to removed unwanted clicks and buzzes
3. do you want to be able to remove background hiss etc?
4. do you want to be able to have the output in different formats
If yes is the answer to any of the above, then you must use a PC, there is no device that I know of which allows these functions. Without a PC you just end up with a stream of unedited audio.
