There are 2 major issues with CCA cable. The first is the ends do not terminate correctly or become loose over time because of the 2 types of metals expand and contract at different rates. The second and much more likely in your case is the distance. There is no certified number that CCA cable can go but the distance is well under the 100 meter limit.
I really wish there was a way to prevent vendors from calling CCA cable CAT 5 or CAT 6 but those terms are not regulated or licensed. The EIA/TIA one is and they can't say their cable meets those standards unless it really does. Now you still find direct ship CCA cable out of china even on amazon that claims EIA/TIA. The standard states the gauge of wire and it must be copper so...
