catalyst 13.8 frame pacing option not showing in CCC
kinskywalker
33
I have a HP laptop with AMD A8M-4500M APU with 7640G integrated graphics and a 7670M dedicated to work in dual graphics mode............
...........after learning that the new 13.8 beta drivers possess the new frame pacing solution for micro stuttering issues faced in dual graphics......I installed them last night..........but the CCC does not shows any option for
turning frame pacing ON or OFF as shown in numerous website as screenshots...............any solution for this????
or any reason why this is not showing up (like is it unsupported?)
it's only for CrossfireX platforms (not the embeded graphics+discrete dual mode) you actually need two identical cards that are connected with the crossfire bridge and i suspect that it's also only working with desktop cards
ok guys....thanks a lot..... yall destroyed my misconceptions.................hope AMD addresses this situation soon.....................................any idea if this issue will be resolved in the future?????
hey k1114 ....ia m being absurd........but is there any way I can just use the discrete gpu provided in my laptop ....with the processor part of the a8 I have..........
it would really help a lot..........
