Catalyst Control Center Issue with GPU scaling, cant fullscreen lower resolutions than native
fuc847
14
whenever i go lower resolution than my native 1920x1080, the screen seems to be using centered timings (maintains the small native resolution with black borders on my panel screen). i WANT to make it scale to full panel size. i'm using HDMI from VGA (r9 290) -> HDMI Monitor (24" playstation tv)
scale image to full panel size is already selected. in the overscan slider, it is greyed out and i cannot change it.
yes
720 is hd 16:9
1080 is full hd 16:9
the next will be 1440 which is 2k 16:9
its abt aspect ratio
if you want to go lower than 720 then try 360 or 480..it might work
