Greetings all,
My friend has a laptop whose CD burner vibrates way more than it is supposed to be vibrating and makes a loud buzz while burning CDs.
Has anyone ever experienced such a thing? I was thinking that maybe something was just loose and could be tightened if I opened up the case but I've never seen this problem.
When you hold a finger on the outside of the drive tray while the CD is burning it stabilizes the drive so the vibration is drastically reduced.
Thanks in advance for any ideas!
-KBundy
-KBundy
