Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
For a reason only known to XP the drive was being identified as a D: drive
(not illogical in itself), but apparently it was conflicting with the
\\server\d\. I have no idea it did not default to Local D as there is a
Local C. The drive therefore was identified as drive I on both machines and
they are now recognized by Explorer and My Network places. I had to make
those changes. One cannot relabel the drive letters in Windows 98.
Everything is now working. Thanks to all for your comments.
Mike
"Mike" wrote:
> The drive is connected through the secondary IDE connector and the jumper is
> set for master. I've downloaded the new firmware from LG and still not
> functioning. LG tells me to return the device back to Future Shop and Future
> Shop tells me to bring the machine(s) to them for installation $45 each plus
> $25 express service. Damn thing is driving me nuts. I guess I'll be without
> the machines for a few hours. I will let the list know what the problem
> solution was so as to defuse anyone's else's agrivation.
> "namniar" wrote:
> > I would suggest using the new 80 wire cable that came with the LG drive and
> > connecting the LG as master on second IDE channel. P.S. double check your
> > jumper settings - single master. Also, check your BIOS to make sure the
> > second IDE channel is enabled.
> > r.
> > "Mike" <Mike@discussions.microsoft.com> wrote in message
> > news:A8586193-77C0-4C9E-B4D4-EFCE08831B57@microsoft.com...
> > > Sorry I don't know anything about Power Toys?
> > > "ShelleyD" wrote:
> > >> Have you ever installed Power Toys?
> > >> If so there is a setting to not show drives that arn't on the system. If
> > >> you uncheck the corresponding drive letters it will allow you to see the
> > >> drive.
> > >> I did this myself a whiile back and not realizing it installed a new
> > >> drive
> > >> that I could not see. Unchecked the box and it was visible.
> > >> Just a possible solution.
> > >> news:B2A37B3F-ED89-4089-AA53-FC3FA47453AC@microsoft.com...
> > >> > I have just installed and uninstalled and reinstalled again an LG
> > >> > CD/DVD
> > >> > drive. The system shows the device working, yet I cannot see it when I
> > >> use
> > >> > windows explorer. I can only see all the other drives on an other
> > >> > tower
> > >> > connected to the network and the server and its drives. On the local
> > >> system
> > >> > it only identifies the C:\ Nothing can play on the drive since it is
> > >> > not
> > >> > recognized. The C:\ is jumpered to master and the CD/DVD is jumpered
> > >> > to
> > >> > slave on the primary IDE connector. I've even tried using it as a
> > >> > master
> > >> on
> > >> > the secondary IDE connector but with identical results.
