G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
But it is being detected as pri or sec master. The problem is that I have
two harddrives (6GB and 4GB) as pri master and sec master respectively.
Neither of the hd's are detected if I set the jumpers to pri or sec slave
with the cdrw as master.
My old cdrw is still detected if I set it as slave, but its cd tray is
broken, hence the new purchase, a Samsung 52x24x52x. PC has mainboard
PCChips M748MR, 400MHz P2 with 128MB RAM. The pc is fairly old, so I don't
plan on buying a new hd.
Does anyone have any suggestions of a configuration that will have the cdrw
set as slave? Is it possible that the Samsung cdrw cannot run as a slave?
To clarify: if I set jumpers so that CDRW = pri master and HD1 = pri slave,
then HD1 is no longer detected.
If I set jumpers so that HD2 = sec master and CDRW = sec slave, then CDRW is
not detected and I get an "ATAPI INCOMPATIBLE Press F1 to Resume" error msg.
Similar scenario with HD1 = pri master and CDRW = pri slave.
If I set jumpers so that HD1 = pri master and HD2 = pri slave, then HD2 is
no longer detected.
If I set jumpers so that CDRW = sec master and HD1 = pri master while
disconnecting HD2, the CDRW is detected and works fine.
Pearlf
no longer detected.
Pearlf
