CELERON 333 MHZ Help!!!
G
Guest
Guest
hi!
I just got from a friend a holco motherboard from shuttle (661VS155)wih a via appolo pro plus chipset, a slot 1 celeron processor at 333MHZ(66*5) and one 128mb sdram dimm from toshiba(PC100-322-722.with this mobo i can adjust the settings either from bios , either from the board with jumpers.from the bios i only could run it at 415mhz(5*83).from the board when i adjust the fsb at 100mhz or more it doesnt boot at all.also on the manual says that there a jumper(45),which if you take it off you could run 66mhz based processors at 100mhz or more.but when i do that the system still doesnt boot.could you help me here, because i have stuck!!!
Did you try 4x100 or 5x100?
At first, try 4x100, then, 4.5x100
5x100 it's kind of crazy!
