Changing Balanced Power Option to High Performance Turbo Boosting?!?!
Alberto Bj
243
Does changing balanced power option to high performance will tear my CPU faster and rise up my electricity bill? i have an i5 4570s and a gtx 1060 3gb,
The reason why I want to always change the power to high performance is because it actually activates turbo boosting when it's set to high performance, the clock speeds rise up to 3.2ghz-3.5ghz even on idle, but when on balanced it only tops up to a maximum of 2.9ghz-3.2ghz even when i play games or run benchmarks. It sounds weird but i don't know why it does that, even though the maximum processor power management of the balanced and high performance is both set to 100% and the only difference is the minimum processor power management of the balanced profile which is 5%.
The extra 200-300mhz gives me more fps on my games especially CPU intensive ones. But I have heard if i always set the power options to high performance all the time, even on idle, will tear down my CPU faster and give a significant change to the electricity bill / power draw and have a significant rise in temperatures (although my temps didn't change).
If it does,
I am finding a way to just make the power plan to switch every time i launch a game so i won't always set the power to high performance.
High Performance sets the minimum CPU state to 100%, that is why you are getting the extra performance as even at idle the PC at full speed. I don't think PC needs to be going at full speed while I am sitting at the desktop. CPU might last longer then.
Did you ask about a batch file that changes the power plan as I know someone who wrote one very much like that in last few days..
i did make a thread about one,. though it's too complicated might aswell just use gameboosters
thanks
