Changing both Motherboard and HD on OEM XP machine..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Sorry for asking such general question, but I'm fearly new to XP issues...
I am about to change to a more modern motherboard to go with my Athlon XP
CPU..
The new mobo supports serial ata disks so I will change boot disk too..
I now have XP Pro on the machine, but will preferably make a new clean
install on the new HD.
Is this possible without getting problems with the activation of XP, as
there is less than 120days since I installed XP on the machine..?
Should I install the new MOBO with existing HD first, reactivate, and then
make a clean install on the new HD?
Can I use XP backup to move all programs to the new hd and change to boot
from the new hd afterwards?
regards
Ottar Tverberg
Sendt med M2 - Operas revolusjonerende e-postprogram:
http://www.opera.com/m2/
> CPU..
> regards
> Ottar Tverberg
Hi Ottar,
if you are using microsoft Oem License preinstalled on you machine you will
be encour problem with actvation process and a new Oem license will be
required.
This is occurs when you upgrade a MB with a Microsoft Oem License.
If you are using a Retail Microsoft License will be require a new
activation process with maybe a call to p.a. this because a microsoft o.s.
like xp can be install on only one 1 machine.
Hi,
As long as it was a retail version, there is no reason you cannot remove the
installation from the old system and install it in the new one. There is no
point to reactivating on the old drive if you are intending on doing a clean
installation. You would have to reactivate anyways. At worst, activation
will require a phone call instead of doing it automatically over the 'net.
Programs should be reinstalled from their original installation media, you
cannot simply copy the old program folders. Data and other settings can be
backed up and imported using the Files and Settings Transfer Wizard, see:
http://aumha.org/win5/a/fast.htm
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"Ottar Tverberg" <otverber@online.no> wrote in message
news😱pspqb3zm3zfmcgu@ottar-91fd56c6a...
> CPU..
> regards
> Ottar Tverberg
> XP CPU..
> then make a clean install on the new HD?
> boot from the new hd afterwards?
> regards
> Ottar Tverberg
Normally, and assuming a retail license (many OEM installations are
not transferable to a new motherboard - check yours before starting),
unless the new motherboard is virtually identical (same chipset, same
IDE controllers, same BIOS version, etc.) to the one on which the WinXP
installation was originally performed, you'll need to perform a repair
(a.k.a. in-place upgrade) installation, at the very least:
How to Perform an In-Place Upgrade of Windows XP
http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q315341
The "why" is quite simple, really, and has nothing to do with
licensing issues, per se; it's a purely technical matter, at this point.
You've pulled the proverbial hardware rug out from under the OS. (If
you don't like -- or get -- the rug analogy, think of it as picking up a
Cape Cod style home and then setting it down onto a Ranch style
foundation. It just isn't going to fit.) WinXP, like Win2K before it,
is not nearly as "promiscuous" as Win9x when it comes to accepting any
old hardware configuration you throw at it. On installation it
"tailors" itself to the specific hardware found. This is one of the
reasons that the entire WinNT/2K/XP OS family is so much more stable
than the Win9x group.
As always when undertaking such a significant change, back up any
important data before starting.
This will also probably require re-activation, unless you have a
Volume Licensed version of WinXP Pro installed. If it's been more than
120 days since you last activated that specific Product Key, you'll most
likely be able to activate via the Internet without problem. If it's
been less, you might have to make a 5 minute phone call.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
> CPU..
> regards
> Ottar Tverberg
Ottar,
generally, you may upgrade or replace all of the hardware components on your
customer's computer and the end user may maintain the license for the
original Microsoft® OEM operating system software, with the exception of an
upgrade or replacement of the motherboard.
An upgrade of the motherboard is considered to result in a "new personal
computer" to which Microsoft® OEM operating system software cannot be
transferred from another computer. If the motherboard is upgraded or
replaced, for reasons other than a defect, then a new computer has been
created and the license of new operating system software is required.
If the motherboard is replaced because it is defective, you do NOT need to
acquire a new operating system license for the PC.
The reason for this licensing rule primarily relates to the end-user license
agreement (EULA) and the support of the software covered by that EULA. The
EULA is a set of usage rights granted to the end-user by the PC manufacturer
and relates only to rights for that software as installed on that particular
PC. The System Builder is required to support the software on that individual
PC. Understanding that end users, over time, upgrade their PC with different
components, Microsoft needed to have one base component "left standing" that
would still define that original PC. Since the motherboard contains the CPU
and is the "heart and soul" of the PC, when the motherboard is replaced (for
reasons other than defect) a new PC is essentially created. The original
System Builder, therefore, can not be expected to support this new PC that
they in effect, did not manufacture.
This info is related ONLY for MIcrosoft Oem License and doesn't affect the
Retail Version FPP
Hope this info can help you
In news😱pspqb3zm3zfmcgu@ottar-91fd56c6a,
Ottar Tverberg <otverber@online.no> respectfully replied ;-)
> issues...
> Athlon XP CPU..
> too..
> as there is less than 120days since I installed XP on the machine..?
> regards
> Ottar Tverberg
Click on the link below, or copy and paste the link into the address box
if using the web based newsgroup.
Move XP to new hardware.
http://www.michaelstevenstech.com/moving_xp.html
Michael Stevens MS-MVP XP
xpnews@bogusmichaelstevenstech.com
For a better newsgroup experience. Setup a newsreader.
http://www.michaelstevenstech.com/outlookexpressnewreader.htm
