Question Changing fan speeds on Lian Li GA II Lite ?
SinfulPride
56
I recently swapped my old Lian Li GA II for a Lian Li GA II Lite. For some reason, I can't change fan speeds like I could with the old one, in l connect, is this natural or did I do something wrong?
The older Gallahad II used an USB port whereby Lian-Li's L-connect was able to access the pump and fan RPM's. See if your motherboard's fan header manipulation software/app helps manage your fans. You could always go into BIOS and then manage a fan curve, provided your motherboard supports it.
I managed to find it using armory crate, it's still a bit loud but managable for now
