Question Changing my G203 Prodigy's switches
lad2525
4
Hello,
I want to replace my Logitech G203 Prodigy's switches using Fantech Crypton VX7's switch (Huano).
My Logitech is 2 years old and my Fantech is brand new.
I would like to know if there could be some compatibility issues if I used the Crypton's switch to my G203 Prodigy.
Thanks.
First, why would you want to perform a transplant of that sort? You're better off just sticking to a mouse in itself. Also, if yo must replace the switches on the Logitech, they're made by Omron which is a top tier grade of switches, akin to how Cherry's switches are better in regards to design and quality.
Thanks for the reply.
I've been using my new mouse for about 3 days now and I can't properly adjust the cursor speed and I can't find a comfortable grip causing my hands to become tired after a prolonged use. In all honesty, this has been driving me crazy since the first day.
Instead of returning it and waiting for another a week or two for the refund or replacement, I would rather use its switches to my worn out Logitech.
Some additional info: I would like to replace all the switches including the 2 side buttons and the dpi switch button.
