So, i’m new to RAM ,,overclocking”, the only thing i did with my latest builds was just enabling XMP/EXPO on. In my current build i have a 9800x3d, Corsair Vengeance 6400mhz cl32, and X870E Aorus Elite. I know the sweet spot for amd 7000 and 9000 is usually 6000 cl30, but if i’m able to make MLCK:ULCK ratio 1:1 (As i believe: FLCK:2133.33, MLCK: 3200, ULCK: 3200)
it will be even better right? But i’ve heard it may depend on something like silicon quality in my chip? If it’s worse it may not be able to run 6400 1:1? If i won’t be able to do it how do i change my ram to 6000mhz cl30, is just setting ram speed to 6000mhz in expo settings and setting some recommended cl30 timings enough or i will need to do some time consuming and complicated tests for it? Also do i need some third party apps for changing MLCK, ULCK and FLCK or i can do it all in bios? What timings do you recommend if I’ll have to run cl30? Sending love to someone that will answer this <3. This forum never disappoints me unlike others.
EDIT: I forgot to mention voltage, will i need to do something with it if i change memory to 6000 30 or just keep it as 6400 32 and it’ll be fine?
