Chassis fan not working
Siard
Hello,
I built my PC about 1,5 years ago and recently I got a problem with the top chassis fan. It won't work (read: rotate) by itself. The LED (of the fan) does work, and when I give it a swing, it will work as long as the PC is turned on. But when I turn it off and back on again, the problem occurs again (so I have to give it a swing again etc...)
I thought it maybe was a problem with the connection to the motherboard, so I switched my front fan connection with the 'broken' top fan connection. The front fan did still work, and still the same problem occured with the top fan...
So another thing I tried to do to resolve the problem, was to connect the 3 pin with a connector directly to the power supply... Again still the problem...
I think I've tried everything now, and I don't have any clue how to resolve this. I hope you can help me. Suggest anything, and I will try it as soon as I possibly can.
For your information, my PC specs (tha matter) are the following:
Chassis: Zalman Z11 Plus
Motherboard: ASRock B75 Pro3-M
Power supply: XFX Pro 550W
CPU: i5 3450
GPU: Gigabyte HD7950 Windforce 3
RAM: Corsair Vengenace
Again, I hope someone can help me with this.
Sorry for my bad English, if you didn't understood. 😉
As far as I know, there's probably just something wrong with the motor. You can buy a 120mm LED fan for $5 from amazon or newegg, or just go without it if you still have other fans in the case.
O.k so I was right about it being broken... Than I have to see if I want to buy a new one.. but it isn't neccesary :)
And otherwise I have to get one with exactly the same LED color.. xD
I will still wait for other answers, but thanks for replying this quick and confirming my suspicions. :)
EDIT: I tried once again to plug out and in the connector from the top fan, and suddenly it works again. The 3 times before it didn't work, but now it does 5 booths in a row... I don't know how, but again thanks! :)
