So I'm getting a new chassis. I've been looking at the Corsair 450D, the new Fractal Design R5, NZHT H440 and Phanteks Enthoo Evolve, among others.
Basically, I got three criteria:
1. I want it to be roomy and have good ventilation possibilities.
2. It needs to be as quiet as possible in terms of the material it uses, if there is a conflict with the first criteria, then somekind of balance is needed, but with some weight for #1.
And then the last part is really less a criteria and more a question: is there a need for a fancontrol like the one in Define R5? The 450D hasn't got any, for instance, but can you use software fan controls? Is there any difference? Can someone please elaborate on this. After all, you typically get a new chassis every 5 years or so, at least I do, so I want to get this one right.
Thanks!
Thanks!
