cheap WiFi card vs expensive WiFi card
The more expensive one supports 802.11ac/b/g/n Wifi, Bluetooth Enhances Data Rate ( idk what that is ) support, also delivers higher internet speed.
The cheaper one still works fine, but doesn't have the features that the expensive one have.
Not much of a difference, still works great...You'll may consider the more expensive one if you have more money and you'll need faster connection.
Hope this helps. :)
The first one supports .ac and bluetooth, the 2nd one doesnt.
What does the modem support?? If it supports ac, probably better to get the first one
Altho some Tplink adapters dont work that good in Win10, and some dont have drivers on the TPlink site
And even if the drivers are on the TPlink site, some of them are crap
Hope this helps. :)
