Checking 1800x temps?
andrewidk
24
Just built a new pc with the Ryzen 1800x and was checking my temps in ryzen master and it said it was idling at 30c but in the bios and NZXTs cam software it says its idling at 60c. Core temp also says its idles at 30c. I feel like this has something to do with me plugging my Fractal design s24 pump header into the wrong spot? I just want to know my actual temps.
Ryzen Master will tell you most accurate temps. All Ryzen "X" processors have 20c offset that BIOS and SW have to take into account. Not all the SW is set to do that and report wrong temps. Make sure you have latest BIOS and SW versions.
Is that cooler Celsius or Kelvin ? Did you follow instructions ?
Thank you for the response! I guess now that i'm looking its only nzxt cam that's showing the temps higher. I wasn't aware of the 20c offset. Ryzen Master shows its hasnt gone over 50c under load so im not as worried anymore. Thank you!
