Checking Motherboard Compatibility Help
Tori-
7
Hi. I was wondering if someone could help check the compatibility of the motherboard I want with the pieces I have. I posted a similar question before but messed up one letter with a typo on my graphics card making it seem like I had a different one. I also changed the motherboard I wanted. Upon catching my mistake I decided to ask for help again just in case. Sorry for the mix up these are the correct pieces. I do not want to buy any other parts except for a motherboard that is compatible with everything I already own. Thank you for helping in advance.
The Motherboard I wish to buy is the ASRock z77 Extreme4. Is that OK? If not what do you recommend from the z77 series?
CPU: Intel core i5 2500k 3.3G
Ram: Corsair (4x4 16GB) CMZ16X3M4A1600C9
Card: XFX-FX-787A CDFC HD 7870 2G R
PSU: Corsair Hx Series 750 W
Hard Drive: Western Digital WD RE4
Fan: Cooler Master Hyper 212 Plus
Case: Corsair Obsidian Series 550D
Thanks again.
