Choice XP Home or Pro
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'm considering the purchase of a new XP computer system. The
machine will be connected to a cable modem. There will be no
networking with any other box by home network or LAN. Should I
purchase XP Home or trade up to XP Pro for an extra $75. Other than
networking features what advantages are there to XP Pro? How about
recovery of data or system resources? Are there other issues I
should know about?
Your kind and expert assistance is very much appreciated.
James E. Morrow
Email to: jamesemorrow@email.com
In news:n6rwyx0sjfux.zuijutpl4flb$.dlg@40tude.net,
James E. Morrow <jamesemorrow@cox.net> typed:
The answer to almost everyone who has to ask this question is
that XP Home is just fine, and the extra features of Professional
would be useless to you.
> Other than
XP Professional and XP Home are exactly the same in all respects,
except that Professional has a few features (mostly related to
networking and security) missing from Home. For most (but not
all) home users, these features aren't needed, would never be
used, and buying Professional instead of Home is a waste of
money.
For details go to
http://www.winsupersite.com/showcase/windowsxp_home_pro.asp
http://www.microsoft.com/windowsxp/whichxp.asp
http://www.microsoft.com/windowsxp/home/howtobuy/choosing2.asp
Also note that Professional allows ten concurrent network
connections, and Home only five.
Ken Blake - Microsoft MVP Windows: Shell/User
Please reply to the newsgroup
> should know about?
The WinXP Home and WinXP Pro versions are _identical_ when it
comes to performance, stability, and device driver and software
application compatibility, but are intended to meet different
functionality, networking, security, and ease-of-use needs, in
different environments. The most significant differences are that
WinXP Pro allows up to 10 simultaneous inbound network connections
while WinXP Home only allows only 5, WinXP Pro is designed to join a
Microsoft domain while WinXP Home cannot, and only WinXP Pro supports
file encryption and IIS. (Oh, and WinXP Pro usually costs roughly $100
USD more than WinXP Home.)
Windows XP Comparison Guide
Which Edition Is Right for You
Windows XP Home Edition vs. Professional Edition
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
>> should know about?
Thank you gentlemen for your prompt and fairly inclusive response.
This should make my decision much easier.
James E. Morrow
XP Pro has more security/backup features built-in. XP Pro is better as a
workstation or as a home PC for a Power User. Me. I have XP Pro, and I have
has XP Home. If you are a novice XP Home should suffice. If you are really
into PC's, Pro is for you.
Also, if you want to ever Remotely-Connect to your PC, you will need Pro.
With Pro, you can connect to the PC from anywhere in the world as if you were
sitting in front of it. Home does not offer that feature. Great if you work
from home and at an office and constantly have to share data.
BMR777
www.rusnakweb.4t.com
