[SOLVED] Choose My Monitor
obeyeddog
Commendable
Apr 18, 2018
14
I need a new monitor. I prefer at least 144hz, and no VA panels. I cannot exceed $300. I'm asking this because I don't know if a higher than 1080p resolution is suitable for my specs. All I need you helpful people to do is find the best monitor you know about for under $300, preferably even lower if possible. I know it's a very open question, 1080p, 27in, anything in the budget, just throw out some ideas. Thanks.
My Specs:
MB: ROG STRIX B350-F GAMING
CPU: Ryzen 5 1600x
GPU: RTX 2060
RAM: 16GB
AOC C27G1 27" <144Hz,curved,1920x1080,1ms response time,VA panel
MSI Optix-MAG274R-bezzels so thin u cant even see them,144hz,1ms response time,1920x1080,IPS panel
In fact check it out yourself,i've checked all your preferences (144Hz,1ms resposne time,27 inch...):
https://www.amazon.com/s?k=monitors&i=computers&rh=n:1292115011,p_n_size_browse-bin:3547807011,p_n_feature_twelve_browse-bin:17726584011,p_n_feature_fifteen_browse-bin:17751810011,p_n_feature_eleven_browse-bin:17726576011&s=price-asc-rank&dc&qid=1602688925&rnid=17726572011&ref=sr_nr_p_n_feature_eleven_browse-bin_4
I like the first one a lot
Reactions: Dj0gany
