I'm building the following config and I'm trying to decide on a case to use, between the Fractal Node 304 and BitFenix Prodigy. I like the relative portability of the node 304 as I could fit it in a gym bag and carry it on the train easily, but I don't think I'll be doing that much travel so I'm not sure how much that matters. I also don't plan to do much upgrading in the future (but you never know). Here is my config:
CPU: Intel Core i5-47990K 3.
CPU Cooler: Corsair Hydro H60 120MM Liquid Cooling Kit
Motherboard: GIGABYTE GA-Z97N-WIFI Mini-ITX w/ 802.11ac WiFi + BT 4.0, Dual GbLAN, 1 PCIe x16, 4x SATA 6Gb/s
Memory: Corsair Vengeance 8GB (4GB x 2) DDR3/1866MHz Dual Channel Memory
Storage: 128GB ADATA SP900 SATA-III 6.0 Gb/s
Storage: 1TB Western Digital Caviar Blue SATA-III 6.0 Gb/s HDD
Video Card: EVGA Superclocked NVIDIA GeForce GTX 770 2GB GDDR5 w/ ACX Cooling PCIe 3.0
Case: Bitfenix Prodigy (Black) or Fractal Design Node 304
Power Supply: Corsair CX600 600W 80 Plus Bronze
Given my config, would either case be more ideal over the other to accommodate the components? Also, would anyone know how the two cases compare in terms of airflow, cooling, and noise? Where I'm getting it the price between the cases is just $10 so price difference isn't much of a deciding issue. Thoughts anyone?
