Choosing full tower ATX gaming case with GOOD airflow! Help!
Nico Da Ninja
45
Hello,
I've been stuck with my thermaltake commander mid tower for a while and I want to upgrade to a case with lots of room for 12 in cards, water cooling etc. My price range is around 100$. Im going to need some good airflow for overclocking and ive been looking at the Fractal Design Define XL R2 FD-CA-DEF-XL-R2-BL Black/Pearl Steel ATX Full Tower Computer Case : http://www.newegg.com/Product/Product.aspx?Item=N82E16811352029
And the Rosewill Thor v2. http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
My color scheme is red/ black.
Specs:
GTX 650 ( soon to be gtx 770)
AMD fx- 4100 3.6ghz
8 GB ddr3 ram
1 TB Seagate hard drive 7200
Gigabyte M68mt-s2 MB ( Getting new one soon) ATX Am3+
Rosewill Capstone 650watt 80plus gold PSU
Nico Da Ninja
45
Illumynization
817
140
The back 120mm I have a push pull with an H60. The top dual 200mm I know you can do push or pull. As for both I think if you mounted rad where the current dual 200mm fans are. I also have some pics I can link when I get home.
I've had it for 3 year's and about 2 months.
Edit: Ok here are some pics and a link to the rest.
http://cdn.overclock.net/6/6a/900x900px-LL-6ab5de79_P1020047.jpeg
http://cdn.overclock.net/4/43/900x900px-LL-436ca081_phamtom.jpeg
http://cdn.overclock.net/f/f6/900x900px-LL-f690abdb_379053_2762546742382_1219244721_33245507_710115137_n.jpeg
http://cdn.overclock.net/b/b1/900x900px-LL-b13c7239__MG_0007.jpeg
http://www.overclock.net/t/876350/lightbox/
Similar threads
