Choosing the right Power Supply help!
Serperior
5
Hello. Can you recommend any good quality power supplies for my new PC build? Will any of these three PSUs be enough for the GTX 960? Thank you
Here are the lists I pick.
Super Flower Golden Green HX 550W
http://www.cclonline.com/product/179386/SF-550P14XE-HX-/Power-Supplies/SuperFlower-Golden-Green-HX-550W-80-Plus-Gold-Power-Supply-Black/PSU0845/?siteID=8BacdVP0GFs-C7QCxplDk5DlpmnyvtHAMQ
Cooler Master V650 Semi-Modular
http://www.cclonline.com/product/153567/RS650-AMAAG1-UK/Power-Supplies/Cooler-Master-VS-Series-V-650W-80plus-Gold-Modular-Power-Supply-Unit-with-UK-Cable/PSU0726/
EVGA SuperNOVA NEX 650W G1
http://www.amazon.co.uk/dp/B00LMAUZ6G/?tag=pcp0f-21
PC specs:
Processor: Intel Core i5-6600 non-K at 3.3GHz (Skylake)
CPU cooler: Cooler Master Hyper 212 EVO
Motherboard: Gigabyte GA-B150M-D3H Micro ATX (LGA 1151)
Memory: 8GB Kingston HyperX Fury (2x4GB) DDR4-2133MHz - Black
Hard drive: 1TB Western Digital Caviar Blue
Graphics card: 4GB EVGA GTX 960 Super Superclocked ACX 2.0+
Case: Phanteks Enthoo Pro with Window – Black
Additional lighting: Satechi Computer RGB LED light strip with Remote control
That Super Flower is a good PSU and more than enough for the build, with a gtx 960 a good 450w unit would work.. The Cooler master is also a good psu but way more than needed(could run 2 960s in SLI, but the motherboard doesn't support SLI). The Evga G1 isn't very good and is overpriced for it's quality level.
