G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Check your voltage test points on the solenoid driver board, see if you lost
the 12 or 18 volt, if not then start checking power to the trough boards,
then back to the board they plug into, then back to the solenoid driver
board. You lost opto power somewhere. LTG
"Greg P" <Gregory.Peetros@verizon.net> wrote in message
news:1124389137.329680.105000@z14g2000cwz.googlegroups.com...
> Well, I finally found the shorted coil it was the right slingshot the
> two coil wires were somehow touching each other, the wire kind of
> worked its way out of the slot on the plastic. Go figure.
> So, I replaced the 2803 on the CPU board and that took care of the
> blown fuses message and the game will atleast boot up but I now get the
> following message.
> Opto trough bad check connectors, wires and 12 volt supply.
> Then when I push the start button I get the following.
> Testing Ringmaster
> Motor Drive:
> Position Switches:
> Direction Drive
> Coin Door Open
> Since you guys were so good at helping me with the coil short,
> hopefully you can lead me in the right direction on these issues.
> I'm trying to learn as I go along. I appreciate everyone's help
> following message.
> Testing Ringmaster
> Motor Drive:
> Position Switches:
> Direction Drive
> Coin Door Open
