cisvc using up all CPU power
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I have found through task manager that the process CISVC
causing my CPU usage to be at 99%. I have learnt that
CISVC has something to do with "microsoft index service
helper" along with cidaemon.exe.
Does anybody else have the same problem?
Can I stop it from loading up everytime I turn the PC on?
Is it an essential process to have running?
Any thoughts would be appreciated.
Peter
"peterpann" <anonymous@discussions.microsoft.com> wrote in message
news:7b3001c484a0$4fb91560$a501280a@phx.gbl...
> Peter
its a service that runs in the nachground and indexes your hd to speed up
searches (if you do them).
If you can live with a somewhat longer response time when searching your HD
for stuff, you can turn this service off.
Go to Control Panel, Performance and Maintenance, Administrative tools,
Services and look for: (guess) Indexing Service. 🙂)
Stop the service and set the startup value to Manual. That will allow the
system to start it if it should need it (for I don't know what reason) and
you'll have your cpu cycles back.
hth
george
Thanks for the helpful reply. I just did what you said,
but haven't rebooted yet. I still don't understand why
the CISVC.exe was taking up all my CPU power though?!?
Cheers,
Peter
>-----Original Message-----
in message
CISVC
on?
>> Peter
your hd to speed up
That will allow the
>hth
>george
see if this applies to your situation and possibly explains it:
CPU usage in the Indexing Service on your Windows XP-based computer
increases to 100 percent
(http://support.microsoft.com/default.aspx?scid=kb;en-us;833228)
george
news:89e501c48566$287f3440$a401280a@phx.gbl...
> Cheers,
> Peter
> in message
> CISVC
> on?
> >> Peter
> your hd to speed up
> That will allow the
> >hth
> >george
